Giriş
Use this guide to upgrade or replace the hard disk drive (HDD) in your Toshiba Satellite L300-04P (PSLB8C-04P01X).
Neye ihtiyacın var
Unlock the battery by sliding the left battery latch to the right.
To remove the battery, hold the spring-loaded right battery latch to the right, then grasp the center battery tab and pull upward.
Use a Phillips #00 screwdriver to loosen the two HDD cover's captive screws.
Remove the cover.
Bir başkası bu kılavuzu tamamladı.
