Ana içeriğe geç
Toshiba Satellite L305-S5875 CCFL Tube Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305-S5875 CCFL Tube Replacement, LCD Screen: adım 1, 1 resimden 1.
    • Open the laptop so that you can see the screen.
  2. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 2, 2 resimden 1. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 2, 2 resimden 2.
    • Remove the four rubber inserts from the four corners of the screen.
    • Once removed, unscrew and remove the four screws found beneath the four rubber inserts.
  3. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 3, 3 resimden 1. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 3, 3 resimden 2. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 3, 3 resimden 3.
    • Use the plastic opening tool to separate the front panel of the laptop from the back panel, pulling the front panel off the laptop.
    • Gently pull the back panel approximately 1 inch away from the screen.
    • Warning: Following step will detach screen from casing. Use caution.
    • Unscrew and remove the 4 screws on the left and right side of the screen; 8 screws in total.
  4. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 4, 3 resimden 1. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 4, 3 resimden 2. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 4, 3 resimden 3.
    • Lay screen down on keyboard.
    • On the back of the screen, locate the ribbon cable that connects the screen to the computer. Remove the tape from the cable if it is present.
    • Carefully remove the ribbon cable by pulling it out of it's socket.
  5. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 5, 3 resimden 1. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 5, 3 resimden 2. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 5, 3 resimden 3.
    • At the bottom of the screen, locate the pink and white wires.
    • Unplug the connector from the circuit board by gently pulling it out.
  6. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 6, 1 resimden 1.
    • Congratulations, you have just removed your screen!
  7. Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: adım 7, 2 resimden 1. Toshiba Satellite L305-S5875 CCFL Tube Replacement, CCFL Tube: adım 7, 2 resimden 2.
    • With the screen now removed from the computer, remove the two screws from the screen's metal enclosure.
    • In addition to removing the screws, remove the tape on the edge of the screen.
  8. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 8, 3 resimden 1. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 8, 3 resimden 2. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 8, 3 resimden 3.
    • Using a plastic opening tool, unhook the latches on the side of the screen's metal enclosure.
    • Once all of the latches are unhooked, genitally pull the metal case up to expose the CCFL tube.
  9. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 9, 2 resimden 1. Toshiba Satellite L305-S5875 CCFL Tube Replacement: adım 9, 2 resimden 2.
    • With the bad CCFL tube now accessible, very carefully remove it from the screen housing.
    • With the spent CCFL tube now removed, replace it with the new replacement tube in the appropriate slot.
    • Note: Make sure you do not break the CCFL tube, as the contents within the tube are toxic to humans.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler
208 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Calaway Spring 2014 UMass Dartmouth, Team 3-1, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G1
4 Üyeler
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 599
