Ana içeriğe geç
Toshiba Satellite L305-S5875 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305-S5875 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Hard Drive Replacement: adım 2, 3 resimden 1. Toshiba Satellite L305-S5875 Hard Drive Replacement: adım 2, 3 resimden 2. Toshiba Satellite L305-S5875 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. Toshiba Satellite L305-S5875 Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Flip the laptop over so that you can see the back. Make sure that the volume scroller is closest to you when it is flipped over.
    • Locate the hard drive compartment. This is in the bottom left hand side of the laptop.
    • Remove the two 5 mm type-0 Phillips head screws that secure the door and save them to a safe location.
    • Remove the hard drive cover.
  4. Toshiba Satellite L305-S5875 Hard Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite L305-S5875 Hard Drive Replacement: adım 4, 2 resimden 2.
    • With the small door removed, find the black ribbon that is attached to the hard drive tray.
    • Carefully pull the ribbon to the left so that the hard drive tray slides out neatly.
  5. Toshiba Satellite L305-S5875 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Remove the four 4.2 mm type-0 Phillips head screws located on the side of the hard drive enclosure.
  6. Toshiba Satellite L305-S5875 Hard Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite L305-S5875 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Remove the hard drive from the tray.
    • Make sure that when you slide the tray back into place, that the ribbon remains easily accessible.
Sonuç
David Zhuo
35 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G5
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 19
Her zaman: 2,422
