Ana içeriğe geç
Toshiba Satellite L305-S5875 Hinge Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: adım 1, 3 resimden 1. Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: adım 1, 3 resimden 2. Toshiba Satellite L305-S5875 Hinge Replacement, Keyboard: adım 1, 3 resimden 3.
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  2. Toshiba Satellite L305-S5875 Hinge Replacement: adım 2, 1 resimden 1.
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  3. Toshiba Satellite L305-S5875 Hinge Replacement: adım 3, 2 resimden 1. Toshiba Satellite L305-S5875 Hinge Replacement: adım 3, 2 resimden 2.
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  4. Toshiba Satellite L305-S5875 Hinge Replacement: adım 4, 2 resimden 1. Toshiba Satellite L305-S5875 Hinge Replacement: adım 4, 2 resimden 2.
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  5. Toshiba Satellite L305-S5875 Hinge Replacement: adım 5, 1 resimden 1.
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
  6. Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: adım 6, 2 resimden 1. Toshiba Satellite L305-S5875 Hinge Replacement, Hinge: adım 6, 2 resimden 2.
    • Close your laptop and flip it over.
    • Remove the 13 screws using a Phillips #00 screwdriver.
  7. Toshiba Satellite L305-S5875 Hinge Replacement: adım 7, 1 resimden 1.
    • Gently disconnect the ribbon cable.
    • Gently disconnect the multicolored cable.
  8. Toshiba Satellite L305-S5875 Hinge Replacement: adım 8, 1 resimden 1.
    • Gently pull the top case from the bottom case of the laptop.
  9. Toshiba Satellite L305-S5875 Hinge Replacement: adım 9, 2 resimden 1. Toshiba Satellite L305-S5875 Hinge Replacement: adım 9, 2 resimden 2.
    • Unscrew the two screws on the hinge. (Be careful to not damage nearby wires)
    • Both hinges shown, but replacing both may not be necessary.
    • Congratulations, you may now remove and replace your hinge!
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tyler
208 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-1, Calaway Spring 2014 UMass Dartmouth, Team 3-1, Calaway Spring 2014 üyesi
UMASSD-CALAWAY-S14S3G1
4 Üyeler
6 adet Kılavuz yazıldı
1Rehber Yorum
Will this work for a Toshiba satellite l655 model
ethanhunemuller - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 32
Her zaman: 6,552
