Ana içeriğe geç
Toshiba Satellite L305-S5875 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305-S5875 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 Keyboard Replacement: adım 2, 3 resimden 1. Toshiba Satellite L305-S5875 Keyboard Replacement: adım 2, 3 resimden 2. Toshiba Satellite L305-S5875 Keyboard Replacement: adım 2, 3 resimden 3.
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: adım 3, 3 resimden 1. Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: adım 3, 3 resimden 2. Toshiba Satellite L305-S5875 Keyboard Replacement, Keyboard: adım 3, 3 resimden 3.
    • Open the laptop so the keyboard is facing you.
    • Using your fingers, remove the thin plastic cover above the keyboard.
    • Potential for device damage: Do not apply too much force when removing the cover piece as it can break.
  4. Toshiba Satellite L305-S5875 Keyboard Replacement: adım 4, 1 resimden 1.
    • Remove the two 4.8 mm screws from underneath the plastic cover piece using a Phillips #00 screwdriver.
  5. Toshiba Satellite L305-S5875 Keyboard Replacement: adım 5, 2 resimden 1. Toshiba Satellite L305-S5875 Keyboard Replacement: adım 5, 2 resimden 2.
    • Starting at the top, gently raise the keyboard enough to remove it from the socket.
    • Potential for device damage: DO NOT pull out the keyboard after it's out of its socket. The keyboard is connected to the hard drive through a data cable and removing forcefully could damage the cable and laptop.
  6. Toshiba Satellite L305-S5875 Keyboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite L305-S5875 Keyboard Replacement: adım 6, 2 resimden 2.
    • Locate the data cable that is connected to the motherboard.
    • Pull the white ZIF connector towards the screen to remove it.
    • Pull the black ribbon cable away from the screen.
  7. Toshiba Satellite L305-S5875 Keyboard Replacement: adım 7, 1 resimden 1.
    • With the black ribbon cable now disconnected, remove the keyboard from its housing.
Sonuç
Congratulations, you have removed the laptops original keyboard and can now replace it with a new one.
To reassemble your device, follow these instructions in reverse order with the new keyboard.
3 farklı kişi bu kılavuzu tamamladı.
Juan
109 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G5
4 Üyeler
10 adet Kılavuz yazıldı
Bir Yorum
It's not so easy to do step 3.
Texas Chick - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 10
Son 30 gün: 15
Her zaman: 3,279
