Ana içeriğe geç
Toshiba Satellite L305-S5875 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305-S5875 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5875 RAM Replacement: adım 2, 3 resimden 1. Toshiba Satellite L305-S5875 RAM Replacement: adım 2, 3 resimden 2. Toshiba Satellite L305-S5875 RAM Replacement: adım 2, 3 resimden 3.
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5875 RAM Replacement, RAM: adım 3, 3 resimden 1. Toshiba Satellite L305-S5875 RAM Replacement, RAM: adım 3, 3 resimden 2. Toshiba Satellite L305-S5875 RAM Replacement, RAM: adım 3, 3 resimden 3.
    • Locate the RAM Module compartment on the bottom side of the laptop.
    • Carefully remove the 4.6mm 0 Phillips head screw and put it in a safe place.
    • Locate the notch on the screw side of the lid and lift to remove it.
  4. Toshiba Satellite L305-S5875 RAM Replacement: adım 4, 3 resimden 1. Toshiba Satellite L305-S5875 RAM Replacement: adım 4, 3 resimden 2. Toshiba Satellite L305-S5875 RAM Replacement: adım 4, 3 resimden 3.
    • Push the metal tabs on the sides of the RAM outward and the RAM will pop up.
    • Gently pull the RAM out.
    • Replace the RAM by sliding the new one into the angled socket similarly to how you removed the old RAM.
    • Gently apply pressure until the metal tabs on the sides click into place.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Elliot Fiske
36 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 20-5, Maness Winter 2013 Cal Poly, Team 20-5, Maness Winter 2013 üyesi
CPSU-MANESS-W13S20G5
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 19
Her zaman: 6,850
