Giriş
Use this guide to remove or install a motherboard on your Toshiba Satellite L305-S5946. It will be necessary to remove the motherboard to replace the GPU. This guide also acts as a prerequisite for the processor and cooling fan installation guides.
Parçalar
Hiçbir parça belirtilmedi.
Turn the laptop upside-down.
Position the laptop so that the display hinges are facing away from you.
Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
Turn each screw until you hear a click.
Use a Phillips #1 screwdriver to turn the screw on the RAM cover.
Turn the screw until you hear a click.
Turn the laptop right-side up.
Lift open the laptop so that the screen faces you.
Use a Phillips #1 screwdriver to remove the twelve 6-mm screws that borders the bottom of the laptop.
Use a Phillips #1 screwdriver to remove a 6-mm screw that is located in the lower middle, as shown.
Use a Phillips #1 screwdriver to remove the three 3-mm screws located in the battery bay.
Use a Phillips #1 screwdriver to remove the one 4-mm screw located near the RAM.
Use a Phillips #1 screwdriver to remove the four 6-mm screws from the two hinge pads that secure the display assembly to the lower laptop section.
Use tweezers to remove the following two connectors:
One of the connectors has one black and one white wire.
The other connector has black, green, red, yellow, and white wires.
Use your fingers to remove the following connector:
The connector is large and is located at the top right corner of the motherboard, as shown.
Remove the power jack connector.
Remove the connector that has one red wire and one black wire.
Remove the connector with red, yellow, green, white, and black wires.
Remove the large connector near the fan.
Gently pull the power jack cable and socket out of its housing. It should come out entirely.
Bir başkası bu kılavuzu tamamladı.
