Giriş
Use this guide to replace a faulty power jack in your Toshiba Satellite L305-S5946, which is usually indicated by the computer failing to charge. You must remove the base housing in order to reach the power jack.
Parçalar
Hiçbir parça belirtilmedi.
Turn the laptop upside-down.
Position the laptop so that the display hinges are facing away from you.
Use a Phillips #1 screwdriver to loosen the two screws on the bottom left-hand side of the hard drive cover.
Turn each screw until you hear a click.
Use a Phillips #1 screwdriver to turn the screw on the RAM cover.
Turn the screw until you hear a click.
Turn the laptop right-side up.
Lift open the laptop so that the screen faces you.
Use a Phillips #1 screwdriver to remove the twelve 6-mm screws that borders the bottom of the laptop.
Use a Phillips #1 screwdriver to remove a 6-mm screw that is located in the lower middle, as shown.
Use a Phillips #1 screwdriver to remove the three 3-mm screws located in the battery bay.
Use a Phillips #1 screwdriver to remove the one 4-mm screw located near the RAM.
Flip over your laptop so that it is right-side up.
Open your laptop so that the screen faces you.
8 farklı kişi bu kılavuzu tamamladı.
