Ana içeriğe geç
Toshiba Satellite L305-S5955 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305-S5955 Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Close the laptop lid and flip the laptop over.
    • Switch the lock button on the left to the unlock position. (The unlock position is to the left side.)
  2. Toshiba Satellite L305-S5955 Hard Drive Replacement: adım 2, 3 resimden 1. Toshiba Satellite L305-S5955 Hard Drive Replacement: adım 2, 3 resimden 2. Toshiba Satellite L305-S5955 Hard Drive Replacement: adım 2, 3 resimden 3.
    • Push the release button to the right.
    • Hold the release button to the right and lift the battery out of its housing.
  3. Toshiba Satellite L305-S5955 Hard Drive Replacement, Hard Drive: adım 3, 1 resimden 1.
    • Locate the hard drive on the laptop, above the part number and serial number sticker
  4. Toshiba Satellite L305-S5955 Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the two screws marked "4" from the hard drive cover
  5. Toshiba Satellite L305-S5955 Hard Drive Replacement: adım 5, 1 resimden 1.
    • Pry up the cover of the hard drive compartment.
  6. Toshiba Satellite L305-S5955 Hard Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite L305-S5955 Hard Drive Replacement: adım 6, 2 resimden 2.
    • Slide hard drive out by pulling gently on the felt handle
  7. Toshiba Satellite L305-S5955 Hard Drive Replacement: adım 7, 1 resimden 1.
    • Remove four outer black screws on the corners of the hard drive case
  8. Toshiba Satellite L305-S5955 Hard Drive Replacement: adım 8, 1 resimden 1.
    • Remove hard drive from the casing by gently sliding the drive out of the case.
  9. Toshiba Satellite L305-S5955 Hard Drive Replacement: adım 9, 1 resimden 1.
    • Complete these steps in reverse order to insert hard drive back into laptop.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Eric
55 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-2, Buehl Fall 2014 Ohio State, Team 1-2, Buehl Fall 2014 üyesi
OSU-BUEHL-F14S1G2
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 1,009
