Ana içeriğe geç
Toshiba Satellite L305-S5955 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305-S5955 Keyboard Replacement, Lock Tabs: adım 1, 1 resimden 1.
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Keyboard Replacement: adım 2, 1 resimden 1.
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Keyboard Replacement, Keyboard: adım 3, 1 resimden 1.
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite L305-S5955 Keyboard Replacement: adım 4, 2 resimden 2.
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Keyboard Replacement: adım 5, 1 resimden 1.
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Keyboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite L305-S5955 Keyboard Replacement: adım 6, 2 resimden 2.
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Chris
1 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-2, Buehl Fall 2014 Ohio State, Team 1-2, Buehl Fall 2014 üyesi
OSU-BUEHL-F14S1G2
4 Üyeler
3 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 957
