Ana içeriğe geç
Toshiba Satellite L305-S5955 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305-S5955 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Make sure before proceeding to power down, remove the charger, and close your laptop, to avoid damaging your device or harming yourself.
    • Flip laptop over and locate the RAM cover in the middle of the laptop.
  2. Toshiba Satellite L305-S5955 RAM Replacement: adım 2, 2 resimden 1. Toshiba Satellite L305-S5955 RAM Replacement: adım 2, 2 resimden 2.
    • Unscrew the screw marked "4"with PH1 screwdriver.
    • Remove cover by lifting up and pulling it out.
  3. Toshiba Satellite L305-S5955 RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite L305-S5955 RAM Replacement: adım 3, 2 resimden 2.
    • Push latches outwards away from the RAM chip until it pops up.
    • Fingers may be pinched by the latches.
    • Pull RAM chip out.
  4. Toshiba Satellite L305-S5955 RAM Replacement: adım 4, 2 resimden 1. Toshiba Satellite L305-S5955 RAM Replacement: adım 4, 2 resimden 2.
    • Repeat Step 3 for the bottom RAM chip.
Sonuç
Samuel Baker
307 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Baechle Spring 2017 IUPUI, Team 1-2, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S1G2
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 291
