Ana içeriğe geç
Toshiba Satellite L305-S5955 Wireless Card Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305-S5955 Wireless Card Replacement, Lock Tabs: adım 1, 1 resimden 1.
    • Slide the lock tabs outward. The right tab will lock into place, but the left tab must be held in place.
  2. Toshiba Satellite L305-S5955 Wireless Card Replacement: adım 2, 1 resimden 1.
    • When you hear a click, lift up and pull out the battery.
  3. Toshiba Satellite L305-S5955 Wireless Card Replacement, Keyboard: adım 3, 1 resimden 1.
    • Use a plastic opening tool to lift out keyboard lining portion located at the top of the keyboard.
  4. Toshiba Satellite L305-S5955 Wireless Card Replacement: adım 4, 2 resimden 1. Toshiba Satellite L305-S5955 Wireless Card Replacement: adım 4, 2 resimden 2.
    • Remove the 3.6 mm Phillips head PH000 screws securing the keyboard.
  5. Toshiba Satellite L305-S5955 Wireless Card Replacement: adım 5, 1 resimden 1.
    • Use plastic opening tool to pry out the keyboard, starting by the 'delete' key in the top right corner.
  6. Toshiba Satellite L305-S5955 Wireless Card Replacement: adım 6, 2 resimden 1. Toshiba Satellite L305-S5955 Wireless Card Replacement: adım 6, 2 resimden 2.
    • Lift the keyboard up and locate the ribbon.
    • Gently pull the ribbon out of its compartment to release it from the motherboard.
  7. Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: adım 7, 3 resimden 1. Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: adım 7, 3 resimden 2. Toshiba Satellite L305-S5955 Wireless Card Replacement, Wireless Card: adım 7, 3 resimden 3.
    • Detach white and black wires by gently pulling straight up.
  8. Toshiba Satellite L305-S5955 Wireless Card Replacement: adım 8, 1 resimden 1.
    • Unscrew both 3 mm Phillips head PH1 screws and allow the wireless card to pop up.
  9. Toshiba Satellite L305-S5955 Wireless Card Replacement: adım 9, 1 resimden 1.
    • Pull the card out vertically.
Sonuç
Samuel Baker
307 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team 1-2, Baechle Spring 2017 IUPUI, Team 1-2, Baechle Spring 2017 üyesi
IUPUI-BAECHLE-S17S1G2
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 4
Her zaman: 824
