Ana içeriğe geç
Toshiba Satellite L305D-S5895 Hard Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305D-S5895 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 1. Toshiba Satellite L305D-S5895 Hard Drive Replacement, Hard Drive: adım 1, 2 resimden 2.
    • Locate these two screws that you will need to remove.
    • Undo these two screws with the Phillips #0 Screwdriver.
  2. Toshiba Satellite L305D-S5895 Hard Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite L305D-S5895 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Use your finger to lift and remove the cover to the Hard Drive.
  3. Toshiba Satellite L305D-S5895 Hard Drive Replacement: adım 3, 3 resimden 1. Toshiba Satellite L305D-S5895 Hard Drive Replacement: adım 3, 3 resimden 2. Toshiba Satellite L305D-S5895 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Pull the black ribbon back and up to remove the Hard Drive.
  4. Toshiba Satellite L305D-S5895 Hard Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite L305D-S5895 Hard Drive Replacement: adım 4, 2 resimden 2.
    • Remove the cover to reveal the hard drive.
  5. Toshiba Satellite L305D-S5895 Hard Drive Replacement: adım 5, 3 resimden 1. Toshiba Satellite L305D-S5895 Hard Drive Replacement: adım 5, 3 resimden 2. Toshiba Satellite L305D-S5895 Hard Drive Replacement: adım 5, 3 resimden 3.
    • Pull out the hard drive using the ribbon attached to it.
Sonuç
Daniel Matheson
355 İtibar
3 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 UMass Dartmouth, Team 2-8, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G8
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 6
Her zaman: 292
