Ana içeriğe geç
Toshiba Satellite L305D-S5895 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305D-S5895 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Locate at the top of the key board a long thin plastic cover that extends from above the Del key to the top of the Esc button.
  2. Toshiba Satellite L305D-S5895 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite L305D-S5895 Keyboard Replacement: adım 2, 2 resimden 2.
    • Pry up this plastic cover using the Spudger, and carefully remove the plastic cover from the laptop.
  3. Toshiba Satellite L305D-S5895 Keyboard Replacement: adım 3, 2 resimden 1. Toshiba Satellite L305D-S5895 Keyboard Replacement: adım 3, 2 resimden 2.
    • After putting the plastic cover to the side, locate the two screws holding the keyboard to the laptop.
    • Remove the screws using the Phillips #0 screwdriver, and place the screws on the magnetic board.
  4. Toshiba Satellite L305D-S5895 Keyboard Replacement: adım 4, 1 resimden 1.
    • Lift the keyboard up in order to remove the cable.
  5. Toshiba Satellite L305D-S5895 Keyboard Replacement: adım 5, 3 resimden 1. Toshiba Satellite L305D-S5895 Keyboard Replacement: adım 5, 3 resimden 2. Toshiba Satellite L305D-S5895 Keyboard Replacement: adım 5, 3 resimden 3.
    • Notice the two white tabs on the compartment holding the cable.
    • Carefully unplug the keyboard from the motherboard by pulling the two white tabs away from the compartment holding the wire.
Sonuç
Tyler GLick
101 İtibar
1 Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 2-8, Isaacson Fall 2016 UMass Dartmouth, Team 2-8, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S2G8
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 368
