Ana içeriğe geç
Toshiba Satellite L305D-S5900 Battery Replacement
  1. Toshiba Satellite L305D-S5900 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Power off your laptop before beginning dissassembly.
    • The left-hand switch and right-hand switch boxed in red located at the bottom on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Battery Replacement: adım 2, 1 resimden 1.
    • Set the right-hand switch near the battery into the unlock position (move switch from left to right).
  3. Toshiba Satellite L305D-S5900 Battery Replacement: adım 3, 1 resimden 1.
    • Set and hold the left hand switch near the battery into its unlock position (move switch from right to left).
  4. Toshiba Satellite L305D-S5900 Battery Replacement: adım 4, 2 resimden 1. Toshiba Satellite L305D-S5900 Battery Replacement: adım 4, 2 resimden 2.
    • While both switches are in their unlocked positions, use a plastic opening tool or your fingers to lift out the battery at the indent between the switches.
    • The right hand switch regardless of initial position will stay or return to the unlock position when a battery is placed back in the slot. To avoid any mishaps, be sure to set the switch back into the lock position while any battery is plugged in.
Sonuç
Sing Yang Cheng
501 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G6
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 10
Her zaman: 246
