Ana içeriğe geç
Toshiba Satellite L305D-S5900 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305D-S5900 Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Power off your laptop before beginning disassembly.
    • The plastic strip boxed in red is located above the keyboard of the computer.
  2. Toshiba Satellite L305D-S5900 Keyboard Replacement: adım 2, 3 resimden 1. Toshiba Satellite L305D-S5900 Keyboard Replacement: adım 2, 3 resimden 2. Toshiba Satellite L305D-S5900 Keyboard Replacement: adım 2, 3 resimden 3.
    • There are three points of contact boxed in red needed to release located at the far left, the far right and the middle of the plastic strip.
    • Remove the plastic strip from one far end progressively towards the other end using a metal spludger.
  3. Toshiba Satellite L305D-S5900 Keyboard Replacement: adım 3, 2 resimden 1. Toshiba Satellite L305D-S5900 Keyboard Replacement: adım 3, 2 resimden 2.
    • Remove the two 5.3 mm Phillips #1 screws that are beneath the strip.
    • The screws located at the far left and far right when the plastic strip is removed.
  4. Toshiba Satellite L305D-S5900 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite L305D-S5900 Keyboard Replacement: adım 4, 2 resimden 2.
    • Use the metal spludger to push the keyboard in the direction of the track pad and then lift the keyboard up.
    • Be careful not to pull too fast as there is still another cable attaching the keyboard.
  5. Toshiba Satellite L305D-S5900 Keyboard Replacement: adım 5, 3 resimden 1. Toshiba Satellite L305D-S5900 Keyboard Replacement: adım 5, 3 resimden 2. Toshiba Satellite L305D-S5900 Keyboard Replacement: adım 5, 3 resimden 3.
    • There are two tab boxed in red is located at each side of the ZIF (zero insertion force) connector.
    • Use a metal spludger to push the tab upward in order to release the cable ribbon.
    • Carefully pull out the ribbon cable from the ZIF (zero insertion force) connector.
Sonuç
Sing Yang Cheng
501 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G6
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 12
Her zaman: 361
