Ana içeriğe geç
Toshiba Satellite L305D-S5900 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305D-S5900 RAM Replacement, RAM: adım 1, 1 resimden 1.
    • Power off your laptop before beginning dissassembly.
    • The 5.3 mm Phillips #1 screw boxed in red is located at the center on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 RAM Replacement: adım 2, 2 resimden 1. Toshiba Satellite L305D-S5900 RAM Replacement: adım 2, 2 resimden 2.
    • Remove the panel that houses the RAM chips by removing the screw that secures it into its spot.
  3. Toshiba Satellite L305D-S5900 RAM Replacement: adım 3, 3 resimden 1. Toshiba Satellite L305D-S5900 RAM Replacement: adım 3, 3 resimden 2. Toshiba Satellite L305D-S5900 RAM Replacement: adım 3, 3 resimden 3.
    • There are two metal holdings boxed in red is located at each side of the RAM chip (left and right).
    • Use a plastic opening tool or your fingers to carefully pull or push up from the underside of the RAM chip until it naturally sits in the socket at an angle.
    • If using too much force, push aside the metal holdings that holds on to the RAM chip on both side then attempt lifting it up
    • There are two RAM chips that can be removes. To remove the second RAM chips follow the same instructed as above.
Sonuç
Sing Yang Cheng
501 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G6
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 278
