Ana içeriğe geç
Toshiba Satellite L305D-S5900 Storage Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305D-S5900 Storage Drive Replacement, Storage Drive: adım 1, 1 resimden 1.
    • Power off your laptop before beginning disassembly.
    • Two 5.3 mm Phillips #1 screws boxed in red are located at the top right corner on the underside of the computer.
  2. Toshiba Satellite L305D-S5900 Storage Drive Replacement: adım 2, 3 resimden 1. Toshiba Satellite L305D-S5900 Storage Drive Replacement: adım 2, 3 resimden 2. Toshiba Satellite L305D-S5900 Storage Drive Replacement: adım 2, 3 resimden 3.
    • Remove the panel that houses the storage drive by unscrewing the two 5.3 mm Phillips #1 screws that hold it into place
  3. Toshiba Satellite L305D-S5900 Storage Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite L305D-S5900 Storage Drive Replacement: adım 3, 2 resimden 2.
    • The standard hard disk drive that comes with this laptop model should have a ribbon attached to it. Pull this ribbon back until the hard drive comes out of the socket.
    • If your drive doesn’t have this ribbon, it can be pushed out of place by wedging a plastic opening tool in between the drive and its socket and push it out.
Sonuç
Sing Yang Cheng
501 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 3-6, Isaacson Fall 2016 UMass Dartmouth, Team 3-6, Isaacson Fall 2016 üyesi
UMASSD-ISAACSON-F16S3G6
2 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 378
