Ana içeriğe geç
Toshiba Satellite L305D-S5950 CD Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305D-S5950 CD Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 CD Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite L305D-S5950 CD Drive Replacement: adım 2, 2 resimden 2.
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 CD Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite L305D-S5950 CD Drive Replacement: adım 3, 2 resimden 2.
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 CD Drive Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 CD Drive Replacement, CD Drive: adım 5, 1 resimden 1.
    • Locate the RAM cover on the underside of the laptop.
  6. Toshiba Satellite L305D-S5950 CD Drive Replacement: adım 6, 1 resimden 1.
    • Use a phillips head #0 screwdriver to remove the screw located on the RAM cover.
  7. Toshiba Satellite L305D-S5950 CD Drive Replacement: adım 7, 2 resimden 1. Toshiba Satellite L305D-S5950 CD Drive Replacement: adım 7, 2 resimden 2.
    • Using your fingers, carefully remove the cover.
Sonuç
William
889 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 üyesi
CLEM-BENSON-S14S1G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 315
