Ana içeriğe geç
Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 2, 2 resimden 2.
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 3, 2 resimden 2.
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: adım 5, 2 resimden 1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement, Hard Disk Drive: adım 5, 2 resimden 2.
    • Unscrew the screws enough to remove the top cover.
  6. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 6, 1 resimden 1.
    • Remove the cover by lifting the right side up at an angle before removing the entire cover.
  7. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 7, 2 resimden 1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 7, 2 resimden 2.
    • Remove the hard drive from the SATA slot by tugging lightly on the ribbon cable to the right.
  8. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 8, 3 resimden 1. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 8, 3 resimden 2. Toshiba Satellite L305D-S5950 Hard Disk Drive Replacement: adım 8, 3 resimden 3.
    • To separate the hard drive from the caddy, unscrew the two screws.
Sonuç
Ricky Baker
217 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 üyesi
CLEM-BENSON-S14S1G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 909
