Ana içeriğe geç
Toshiba Satellite L305D-S5950 LCD Screen Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 2, 2 resimden 1. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 2, 2 resimden 2.
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 3, 2 resimden 1. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 3, 2 resimden 2.
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Keyboard: adım 5, 2 resimden 1. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Keyboard: adım 5, 2 resimden 2.
    • Locate the plastic strip at the top of the keyboard.
    • Use a pry tool to remove the plastic strip.
    • Using your hands pull out the rest of the plastic strip.
  6. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 6, 1 resimden 1.
    • Use a phillips head #0 screwdriver to remove the two 3.75mm screws holding the keyboard in place.
  7. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 7, 3 resimden 1. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 7, 3 resimden 2. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 7, 3 resimden 3.
    • Lift up the top of the keyboard to remove it.
    • Under the keyboard there is a ribbon cable connecting the keyboard to the laptop. Do not just quickly pull out the keyboard.
    • Unlock the ribbon cable by pushing on the locks that are located on both sides of ribbon cable.
    • Unplug the ribbon cable from the laptop.
  8. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 8, 1 resimden 1.
    • Remove the keyboard completely from the laptop.
  9. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Motherboard Cover: adım 9, 2 resimden 1. Toshiba Satellite L305D-S5950 LCD Screen Replacement, Motherboard Cover: adım 9, 2 resimden 2.
    • Remove all 6.75mm screws from the bottom of the laptop. The 3 screws under the battery are 3.75mm.
    • Remove all 5.25mm screws from the top of the laptop.
  10. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 10, 3 resimden 1. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 10, 3 resimden 2. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 10, 3 resimden 3.
    • Unplug the wires highlighted with red squares.
    • Using a pry tool and yours hands to remove the motherboard cover.
  11. Toshiba Satellite L305D-S5950 LCD Screen Replacement, LCD Screen: adım 11, 3 resimden 1. Toshiba Satellite L305D-S5950 LCD Screen Replacement, LCD Screen: adım 11, 3 resimden 2. Toshiba Satellite L305D-S5950 LCD Screen Replacement, LCD Screen: adım 11, 3 resimden 3.
    • Located and unscrew the four 5.25mm screws located on the four corners of the LCD screen.
    • There might be teflon pads covering them that need to be removed to see the screws.
    • Use your hands to pry off the frame around the LCD screen.
    • Remove the frame from the LCD screen.
  12. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 12, 2 resimden 1. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 12, 2 resimden 2.
    • Remove the four 5.25mm screws on the sides of the LCD screen (this step will be done two times, for either side of the screen).
    • Remove the 5.25mm screw shown in the second picture.
    • Laptop has been rotated 180 degrees to complete the last step.
  13. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 13, 3 resimden 1. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 13, 3 resimden 2. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 13, 3 resimden 3.
    • Unplug the wire located on the right side of the chip under the LCD screen
    • Unplug the wire located on the left side of the chip under the LCD screen. (Laptop has been rotated 180 degrees to complete this step)
    • Unplug the LCD screen from the motherboard.
  14. Toshiba Satellite L305D-S5950 LCD Screen Replacement: adım 14, 1 resimden 1.
    • Remove the LCD screen from the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
William
889 İtibar
7 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 üyesi
CLEM-BENSON-S14S1G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 7
Her zaman: 887
