Ana içeriğe geç
Toshiba Satellite L305D-S5950 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L305D-S5950 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the two sliding battery locks on the underside of the laptop.
  2. Toshiba Satellite L305D-S5950 RAM Replacement: adım 2, 2 resimden 1. Toshiba Satellite L305D-S5950 RAM Replacement: adım 2, 2 resimden 2.
    • Locate the right battery lock and slide it to the right.
  3. Toshiba Satellite L305D-S5950 RAM Replacement: adım 3, 2 resimden 1. Toshiba Satellite L305D-S5950 RAM Replacement: adım 3, 2 resimden 2.
    • While holding the left battery lock to the left, lift up the battery using the tab located on the top center of the battery.
  4. Toshiba Satellite L305D-S5950 RAM Replacement: adım 4, 1 resimden 1.
    • Remove the battery from the laptop.
  5. Toshiba Satellite L305D-S5950 RAM Replacement, RAM: adım 5, 3 resimden 1. Toshiba Satellite L305D-S5950 RAM Replacement, RAM: adım 5, 3 resimden 2. Toshiba Satellite L305D-S5950 RAM Replacement, RAM: adım 5, 3 resimden 3.
    • Unscrew the RAM cover and rotate the cover up to remove it. The screw should not be fully removed from the cover itself.
  6. Toshiba Satellite L305D-S5950 RAM Replacement: adım 6, 2 resimden 1. Toshiba Satellite L305D-S5950 RAM Replacement: adım 6, 2 resimden 2.
    • Push the small levers at the sides of the RAM module away from each other. The RAM module should automatically rotate upwards.
  7. Toshiba Satellite L305D-S5950 RAM Replacement: adım 7, 2 resimden 1. Toshiba Satellite L305D-S5950 RAM Replacement: adım 7, 2 resimden 2.
    • Remove the RAM module by pulling it out at the angle it was rotated to.
  8. Toshiba Satellite L305D-S5950 RAM Replacement: adım 8, 3 resimden 1. Toshiba Satellite L305D-S5950 RAM Replacement: adım 8, 3 resimden 2. Toshiba Satellite L305D-S5950 RAM Replacement: adım 8, 3 resimden 3.
    • If you want to replace the second RAM module, apply steps 2 and 3 to do so.
Sonuç
To reassemble your device, follow these instructions in reverse order. When placing the RAM chips in, push them down until the levers snap into place after inserting them into the slot.
Ricky Baker
217 İtibar
2 adet Kılavuz yazıldı
Ekip
Clemson, Team 1-2, Benson Spring 2014 Clemson, Team 1-2, Benson Spring 2014 üyesi
CLEM-BENSON-S14S1G2
3 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 438
