Ana içeriğe geç
Toshiba Satellite L35-S2174 Battery Replacement
  1. Toshiba Satellite L35-S2174 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Battery Replacement: adım 2, 2 resimden 1. Toshiba Satellite L35-S2174 Battery Replacement: adım 2, 2 resimden 2.
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Battery Replacement: adım 3, 2 resimden 1. Toshiba Satellite L35-S2174 Battery Replacement: adım 3, 2 resimden 2.
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Battery Replacement: adım 4, 1 resimden 1.
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
Sonuç
Amani Mitchell
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Catania Fall 2016 UMass Dartmouth, Team 1-4, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G4
3 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 12
Her zaman: 335
