Ana içeriğe geç
Toshiba Satellite L35-S2174 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L35-S2174 Keyboard Replacement, Battery: adım 1, 1 resimden 1.
    • Turn the laptop off to prevent the possibility of electric shock or damage to the computer.
    • Flip the laptop so that the bottom is facing upwards.
  2. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 2, 2 resimden 2.
    • Slide the battery lock switch to the left.
  3. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 3, 2 resimden 1. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 3, 2 resimden 2.
    • Pull the sliding switch to the right and continue to hold it in this position.
  4. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 4, 1 resimden 1.
    • While holding the switch, slide the battery away from you.
    • You do not need to hold the switch when putting the battery back into the laptop.
  5. Toshiba Satellite L35-S2174 Keyboard Replacement, Keyboard: adım 5, 2 resimden 1. Toshiba Satellite L35-S2174 Keyboard Replacement, Keyboard: adım 5, 2 resimden 2.
    • Remove the two circled 4mm screws with a J1 screwdriver.
  6. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 6, 2 resimden 1. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 6, 2 resimden 2.
    • Remove the two circled 5mm screws with a J1 screwdriver.
  7. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 7, 2 resimden 1. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 7, 2 resimden 2.
    • Use a spudger to pry up the plastic panel between the keyboard the screen.
    • Repeat on opposite side of laptop.
    • The panel may be difficult to remove.
    • Tilt the laptop's screen back.
    • Lift the panel and remove it from the laptop.
  8. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 8, 2 resimden 1. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 8, 2 resimden 2.
    • There is a ribbon cable underneath the keyboard. Don't lift the keyboard too forcefully or you may break the ribbon cable.
    • Unclip the keyboard from the laptop by lifting it.
    • Slide the keyboard slightly towards the screen.
    • Lift the keyboard out of the way.
  9. Toshiba Satellite L35-S2174 Keyboard Replacement: adım 9, 1 resimden 1.
    • Pull the ribbon cable straight out of the connector.
    • To reinstall the cable, hold it near the end and push it straight into the connector, being careful not to kink the cable.
Sonuç
Amani Mitchell
401 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Catania Fall 2016 UMass Dartmouth, Team 1-4, Catania Fall 2016 üyesi
UMASSD-CATANIA-F16S1G4
3 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 363
