Ana içeriğe geç
Toshiba Satellite L45-S7423 Battery Replacement
  1. Toshiba Satellite L45-S7423 Battery Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L45-S7423 Battery Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L45-S7423 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Battery Replacement: adım 2, 2 resimden 1. Toshiba Satellite L45-S7423 Battery Replacement: adım 2, 2 resimden 2.
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Battery Replacement: adım 3, 2 resimden 1. Toshiba Satellite L45-S7423 Battery Replacement: adım 3, 2 resimden 2.
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
Sonuç
Stephen Sippel
194 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G54
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 2,476
