Ana içeriğe geç
Toshiba Satellite L45-S7423 Dial Up Modem Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 2, 2 resimden 1. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 2, 2 resimden 2.
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 3, 2 resimden 1. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 3, 2 resimden 2.
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Bottom Access Panel: adım 4, 3 resimden 1. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Bottom Access Panel: adım 4, 3 resimden 2. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Bottom Access Panel: adım 4, 3 resimden 3.
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 5, 3 resimden 1. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 5, 3 resimden 2. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 5, 3 resimden 3.
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Dial Up Modem: adım 6, 2 resimden 1. Toshiba Satellite L45-S7423 Dial Up Modem Replacement, Dial Up Modem: adım 6, 2 resimden 2.
    • Remove the two screws holding modem in place.
    • Two 3.6 mm Phillips screws.
  7. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 7, 2 resimden 1. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 7, 2 resimden 2.
    • Using a plastic removal tool, dislodge the modem. This separates a small connections on the underside of the modem.
  8. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 8, 3 resimden 1. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 8, 3 resimden 2. Toshiba Satellite L45-S7423 Dial Up Modem Replacement: adım 8, 3 resimden 3.
    • Grab the black insert connected to the modem. Gently pull the insert outwards to disconnect the cable.
Sonuç
Stephen Sippel
194 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G54
4 Üyeler
18 adet Kılavuz yazıldı
Bir Yorum
Does someone know anything about the modem connector connecting the modem to the motherboard? Any information like part number, name, manufacturer would be handy.
Kamil - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 873
