Ana içeriğe geç
Toshiba Satellite L45-S7423 LCD Display Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L45-S7423 LCD Display Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 2, 2 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 2, 2 resimden 2.
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 3, 2 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 3, 2 resimden 2.
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: adım 4, 3 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: adım 4, 3 resimden 2. Toshiba Satellite L45-S7423 LCD Display Replacement, Bottom Access Panel: adım 4, 3 resimden 3.
    • Remove the 5 Phillips screws holding the panel in place.
    • These screws are permanently fastened to the panel; they are designed to be removed only partially to avoid loss.
  5. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 5, 3 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 5, 3 resimden 2. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 5, 3 resimden 3.
    • Use a finger to remove the panel by lifting up on the provided removal tab.
  6. Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: adım 6, 3 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: adım 6, 3 resimden 2. Toshiba Satellite L45-S7423 LCD Display Replacement, LCD Display: adım 6, 3 resimden 3.
    • Remove the Phillips screw holding the panel in place and then use a finger to remove the panel.
    • This screw is not designed to be completely removed, it is permanently fastened to the panel to avoid loss.
  7. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 7, 3 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 7, 3 resimden 2. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 7, 3 resimden 3.
    • With the aid of a plastic removal, disconnect the two wires attached to the wireless card.
  8. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 8, 1 resimden 1.
    • Remove the yellow tape holding the black and the white wires in place.
  9. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 9, 3 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 9, 3 resimden 2. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 9, 3 resimden 3.
    • Unwind the wires from the plastic tabs holding the wires in place.
  10. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 10, 2 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 10, 2 resimden 2.
    • Remove the screw holding the ground cable in place.
    • One 4.5 mm Phillips screw.
  11. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 11, 2 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 11, 2 resimden 2.
    • Disconnect the video cable connecting the display to the base of the laptop.
  12. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 12, 3 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 12, 3 resimden 2. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 12, 3 resimden 3.
    • Pop off the laptop's hinge covers using a spudger tool.
    • Only a small amount of force is required. Excessive force may permanently damage the hinge covers.
  13. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 13, 2 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 13, 2 resimden 2.
    • Remove the two screws on the back side of the laptop holding the LCD display in place.
    • Two 8.5 mm Phillips screws.
  14. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 14, 2 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 14, 2 resimden 2.
    • Remove the final two screws on the bottom side of the laptop holding the LCD display in place.
  15. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 15, 3 resimden 1. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 15, 3 resimden 2. Toshiba Satellite L45-S7423 LCD Display Replacement: adım 15, 3 resimden 3.
    • Carefully pull apart the LCD display from the base by pulling vertically upwards on the display.
    • Be careful as you remove the display not to pull too hard on the cables as they pass through the opening.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Stephen Sippel
194 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G54
4 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 11
Her zaman: 1,950
