Ana içeriğe geç
Toshiba Satellite L45-S7423 Optical Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L45-S7423 Optical Drive Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure the battery lock switch is switched to the unlocked position.
    • The battery is unlocked when the battery lock switch is slid to the side with an image of an unlocked lock.
  2. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 2, 2 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 2, 2 resimden 2.
    • Slide the battery release switch to the left.
    • The switch is spring loaded, so you must hold the switch in place while removing the battery.
  3. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 3, 2 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 3, 2 resimden 2.
    • Using a finger, lift up the battery.
    • The battery release switch must be held in place.
  4. Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: adım 4, 3 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: adım 4, 3 resimden 2. Toshiba Satellite L45-S7423 Optical Drive Replacement, Optical Drive: adım 4, 3 resimden 3.
    • Remove the two screws holding the hard drive panel down.
    • These screw are permanently fastened to the panel; they are designed to be removed only partially.
  5. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 5, 1 resimden 1.
    • Use a finger to lift up on the tab and remove the panel.
  6. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 6, 2 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 6, 2 resimden 2.
    • Remove the screw that holds in place the optical drive.
    • One 4.6 mm Phillips screw.
  7. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 7, 2 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 7, 2 resimden 2.
    • Locate the small rectangular hole and insert the spudger.
    • Gently slide the metal flange to the right to dislodge the optical drive.
  8. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 8, 1 resimden 1.
    • The optical drive will become partially exposed.
  9. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 9, 2 resimden 1. Toshiba Satellite L45-S7423 Optical Drive Replacement: adım 9, 2 resimden 2.
    • Pull the optical drive to remove it from the computer body.
Sonuç
Stephen Sippel
194 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 21-54, Johann Spring 2013 Cal Poly, Team 21-54, Johann Spring 2013 üyesi
CPSU-JOHANN-S13S21G54
4 Üyeler
18 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 12
Her zaman: 932
