Ana içeriğe geç
Toshiba Satellite L455-S5046 Hard-drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite L455-S5046 Hard-drive Replacement, Battery: adım 1, 2 resimden 2.
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 Hard-drive Replacement, Hard-drive: adım 2, 1 resimden 1.
    • Locate the hard drive in the upper right corner on the back of the computer.
    • Unscrew the 2 Phillips #0 7-mm screws holding the cover in place and remove the cover.
  3. Toshiba Satellite L455-S5046 Hard-drive Replacement: adım 3, 1 resimden 1.
    • Once the cover is off, the hard drive will be exposed, carefully pull it out to the right.
Sonuç
Daryl Spurgeon
610 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 321
