Ana içeriğe geç
Toshiba Satellite L455-S5046 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Toshiba Satellite L455-S5046 Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Lift the plastic strip above the keyboard. If you use a lever to pick up the left edge it should pop off.
    • Use the Phillips #0 screwdriver to remove the two indicated 5-mm screws.
  2. Toshiba Satellite L455-S5046 Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite L455-S5046 Keyboard Replacement: adım 2, 2 resimden 2.
    • Remove the keyboard slowly. It will be attached to the laptop by a plastic connector, which can be disconnected from the laptop by pulling gently.
Sonuç
Daryl Spurgeon
610 İtibar
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 414
