Ana içeriğe geç
Toshiba Satellite L455-S5046 Optical Drive Replacement
Neye ihtiyacın var
Videoya Genel Bakış
  1. Toshiba Satellite L455-S5046 Optical Drive Replacement, Optical Drive: adım 1, 1 resimden 1.
    • Unscrew 1 Phillips #0 7-mm screw on the back of the computer.
  2. Toshiba Satellite L455-S5046 Optical Drive Replacement: adım 2, 1 resimden 1.
    • Lift the plate and gently pull it away from yourself, until it is removed.
  3. Toshiba Satellite L455-S5046 Optical Drive Replacement: adım 3, 1 resimden 1.
    • Unscrew the 1 Phillips #0 7-mm screw, located on the right side where the silver tabs of the optical drive poke out.
  4. Toshiba Satellite L455-S5046 Optical Drive Replacement: adım 4, 2 resimden 1. Toshiba Satellite L455-S5046 Optical Drive Replacement: adım 4, 2 resimden 2.
    • The optical drive is partially visible and push it to the right.
    • The optical drive should pop out on the right side, and you can gently pull it out.
Sonuç
Daryl Spurgeon
610 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 9
Her zaman: 180
