Ana içeriğe geç
Toshiba Satellite L455-S5046 The Fan Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L455-S5046 The Fan Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite L455-S5046 The Fan Replacement, Battery: adım 1, 2 resimden 2.
    • Find the battery on the back of the computer. Slide both tabs outward towards the side of the laptop and the battery will come loose.
    • Insert your finger under the middle tab and lift the battery out.
  2. Toshiba Satellite L455-S5046 The Fan Replacement, Fan: adım 2, 1 resimden 1.
    • Start on the back and unscrew the 12 Phillips #0 11-mm screws holding the back cover down.
  3. Toshiba Satellite L455-S5046 The Fan Replacement: adım 3, 1 resimden 1.
    • Pop off the hard drive cover, and then unscrew the four 11-mm Phillips #0 screws.
  4. Toshiba Satellite L455-S5046 The Fan Replacement: adım 4, 2 resimden 1. Toshiba Satellite L455-S5046 The Fan Replacement: adım 4, 2 resimden 2.
    • Flip the laptop over. Remove the keyboard as instructed in the keyboard replacement guide.
    • Gently remove the connector visible in the upper right hand corner of the laptop by pulling to the right.
    • Remove the cover slowly. There will be two other connectors on the underside that can be removed by pulling gently.
  5. Toshiba Satellite L455-S5046 The Fan Replacement: adım 5, 2 resimden 1. Toshiba Satellite L455-S5046 The Fan Replacement: adım 5, 2 resimden 2.
    • Remove the connector between the fan and the laptop by pulling gently to the left.
    • Remove the two indicated 11-mm Phillips #0 screws.
  6. Toshiba Satellite L455-S5046 The Fan Replacement: adım 6, 1 resimden 1.
    • Now gently lift the fan and pull out.
Sonuç
Daryl Spurgeon
610 İtibar
6 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 2
Son 30 gün: 7
Her zaman: 263
