Ana içeriğe geç
Toshiba Satellite L455-S5975 Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: adım 1, 2 resimden 1. Toshiba Satellite L455-S5975 Keyboard Replacement, Keyboard: adım 1, 2 resimden 2.
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Keyboard Replacement: adım 2, 1 resimden 1.
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Keyboard Replacement: adım 3, 1 resimden 1.
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Keyboard Replacement: adım 4, 2 resimden 1. Toshiba Satellite L455-S5975 Keyboard Replacement: adım 4, 2 resimden 2.
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mike Kennedy
160 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-21, Maness Spring 2013 Cal Poly, Team 2-21, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G21
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 2,403
