Ana içeriğe geç
Toshiba Satellite L455-S5975 LCD Display Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L455-S5975 LCD Display Replacement, Keyboard: adım 1, 2 resimden 1. Toshiba Satellite L455-S5975 LCD Display Replacement, Keyboard: adım 1, 2 resimden 2.
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 2, 1 resimden 1.
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 3, 1 resimden 1.
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 4, 2 resimden 1. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 4, 2 resimden 2.
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
  5. Toshiba Satellite L455-S5975 LCD Display Replacement, Fan: adım 5, 2 resimden 1. Toshiba Satellite L455-S5975 LCD Display Replacement, Fan: adım 5, 2 resimden 2.
    • Flip the laptop over to access the battery.
    • Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
  6. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 6, 1 resimden 1.
    • Remove the twelve 10mm screws with a Phillips #00 screwdriver.
    • Remove the cover over the hard drive (upper right in photo) and remove the four 10mm screws at the four corners.
  7. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 7, 1 resimden 1.
    • Remove the three 4mm screws with a Phillips #00 screwdriver.
  8. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 8, 1 resimden 1.
    • Flip the laptop over so it's in the right-side-up position.
    • Lift the grey plastic casing up and unhook any wires attached to the casing.
    • Remove the five 10mm screws, each with a label 'F10' next to them.
  9. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 9, 2 resimden 1. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 9, 2 resimden 2.
    • Disconnect the flat thin wire connecting the track pad to the motherboard by pulling it straight out.
    • Disconnect the thin red wire on the right side of the motherboard.
  10. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 10, 1 resimden 1.
    • Remove the two 6mm screws with a Phillips #00 screwdriver.
  11. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 11, 2 resimden 1. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 11, 2 resimden 2.
    • Disconnect the red and yellow wires connecting the fan to the motherboard by pulling the wires straight out.
    • Remove the fan.
  12. Toshiba Satellite L455-S5975 LCD Display Replacement, LCD Display: adım 12, 2 resimden 1. Toshiba Satellite L455-S5975 LCD Display Replacement, LCD Display: adım 12, 2 resimden 2.
    • Remove the following six screws located at the base of the monitor:
    • Three 5mm Phillip Head Screws
    • Two 6mm Phillip Head Screws
    • One 7mm Phillip Head Screw
    • Disconnect the long thing grey cable that is attached to the motherboard by pulling it out.
  13. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 13, 2 resimden 1. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 13, 2 resimden 2.
    • Remove 2 plastic plugs using a spudger located behind the corners of the rotating part of the LCD.
    • Remove two 5mm Phillips head screws located where the plugs used to be.
  14. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 14, 1 resimden 1.
    • Remove the black and white wires connected to the LCD. The wires are located under the motherboard and can be accessed through the back panel of the computer.
    • Use a spudger to remove wires by pushing the wires upward, away from the logic board.
  15. Toshiba Satellite L455-S5975 LCD Display Replacement: adım 15, 1 resimden 1.
    • Remove the LCD Screen
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Mike Kennedy
160 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-21, Maness Spring 2013 Cal Poly, Team 2-21, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G21
4 Üyeler
5 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 15
Her zaman: 3,614
