Ana içeriğe geç
Toshiba Satellite L455-S5975 Logic Board Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L455-S5975 Logic Board Replacement, Keyboard: adım 1, 2 resimden 1. Toshiba Satellite L455-S5975 Logic Board Replacement, Keyboard: adım 1, 2 resimden 2.
    • Before repairing your laptop, power down the system, disconnect the charger if necessary and remove the battery.
    • Use the flat edge of the plastic opening tool to pry open the narrow plastic strip above the keyboard.
  2. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 2, 1 resimden 1.
    • Remove the three 3mm screws with a Phillips#00 Screwdriver.
  3. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 3, 1 resimden 1.
    • Lift the keyboard away from the top side of the laptop.
    • Do not pull the keyboard away too hard. It is still connected by the fragile ribbon cable (shown in the red square).
  4. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 4, 2 resimden 1. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 4, 2 resimden 2.
    • Disconnect the keyboard cable that is still attached to the keyboard.
    • Unlatch the fastener.
    • Using your hands, pull the keyboard connector out, not up.
  5. Toshiba Satellite L455-S5975 Logic Board Replacement, Fan: adım 5, 2 resimden 1. Toshiba Satellite L455-S5975 Logic Board Replacement, Fan: adım 5, 2 resimden 2.
    • Flip the laptop over to access the battery.
    • Remove the battery by sliding fingers away from each other and lifting up the tab at the same time.
  6. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 6, 1 resimden 1.
    • Remove the twelve 10mm screws with a Phillips #00 screwdriver.
    • Remove the cover over the hard drive (upper right in photo) and remove the four 10mm screws at the four corners.
  7. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 7, 1 resimden 1.
    • Remove the three 4mm screws with a Phillips #00 screwdriver.
  8. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 8, 1 resimden 1.
    • Flip the laptop over so it's in the right-side-up position.
    • Lift the grey plastic casing up and unhook any wires attached to the casing.
    • Remove the five 10mm screws, each with a label 'F10' next to them.
  9. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 9, 2 resimden 1. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 9, 2 resimden 2.
    • Disconnect the flat thin wire connecting the track pad to the motherboard by pulling it straight out.
    • Disconnect the thin red wire on the right side of the motherboard.
  10. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 10, 1 resimden 1.
    • Remove the two 6mm screws with a Phillips #00 screwdriver.
  11. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 11, 2 resimden 1. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 11, 2 resimden 2.
    • Disconnect the red and yellow wires connecting the fan to the motherboard by pulling the wires straight out.
    • Remove the fan.
  12. Toshiba Satellite L455-S5975 Logic Board Replacement, Logic Board: adım 12, 1 resimden 1.
    • Remove the following with a Phillips #00 Screwdriver:
    • Six 7mm Phillips Head screws
    • One 5 mm Phillips Head screw
    • Remove the LCD screen tab
  13. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 13, 2 resimden 1. Toshiba Satellite L455-S5975 Logic Board Replacement: adım 13, 2 resimden 2.
    • A red wire connects the motherboard to the computer, so release the wire by pulling it straight out.
    • After all the screws are removed, lift the motherboard up and away from the earphone jacks that are located at the front of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Mike Kennedy
160 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-21, Maness Spring 2013 Cal Poly, Team 2-21, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G21
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 14
Her zaman: 3,054
