Ana içeriğe geç
Toshiba Satellite L455-S5975 WiFi Card Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L455-S5975 WiFi Card Replacement, WiFi Card: adım 1, 1 resimden 1.
    • Flip Laptop into an upside-down position.
    • Push latches (indicated in red) outward.
    • Lift battery by notch (indicated in green) to remove.
  2. Toshiba Satellite L455-S5975 WiFi Card Replacement: adım 2, 2 resimden 1. Toshiba Satellite L455-S5975 WiFi Card Replacement: adım 2, 2 resimden 2.
    • Remove the plastic cover closest to the battery by first unscrewing the single 7mm screw (in red) with the phillips #00 screwdriver.
    • Now, lift the cover by the notch under the screw (in red) using a plastic opening tool.
  3. Toshiba Satellite L455-S5975 WiFi Card Replacement: adım 3, 3 resimden 1. Toshiba Satellite L455-S5975 WiFi Card Replacement: adım 3, 3 resimden 2. Toshiba Satellite L455-S5975 WiFi Card Replacement: adım 3, 3 resimden 3.
    • Locate the Wifi Card on the right-hand side of compartment you just revealed
    • Remove the black and white wire by carefully pulling them off with the plastic lever (you will hear a light snapping sound).
  4. Toshiba Satellite L455-S5975 WiFi Card Replacement: adım 4, 1 resimden 1.
    • Unscrew the two 6 mm screws (indicated in red) located at the bottom of the WiFi card and store them in a safe place.
  5. Toshiba Satellite L455-S5975 WiFi Card Replacement: adım 5, 2 resimden 1. Toshiba Satellite L455-S5975 WiFi Card Replacement: adım 5, 2 resimden 2.
    • Gently remove the wifi card from the laptop.
Sonuç
Note: When installing new WiFi card be sure to connect the black wire to the right where there is a small letter “B” imprinted and place white on the opposite side.
2 farklı kişi bu kılavuzu tamamladı.
Dylan Baker
188 İtibar
1 Kılavuz yazıldı
Ekip
UMD team 2 UMD team 2 üyesi
Community
4 Üyeler
1 Kılavuz yazıldı
Bir Yorum
are you aware of any compatible upgrades for a faster speed, like a dual band 5ghz card? from what im gathering its probably not worth the trial and error, because the antenna is designed probably for just 2.4ghz, so i'm thinking a usb dongle is the best option but wondering what your thoughts are? great guide btw
Tyler Bombara - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 20
Her zaman: 2,260
