Ana içeriğe geç
Toshiba Satellite L455D-S5976 CPU Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L455D-S5976 CPU Replacement, Battery: adım 1, 1 resimden 1.
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 CPU Replacement: adım 2, 1 resimden 1.
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 CPU Replacement: adım 3, 1 resimden 1.
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 CPU Replacement, Optical Drive: adım 4, 1 resimden 1.
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 CPU Replacement: adım 5, 1 resimden 1.
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 CPU Replacement: adım 6, 1 resimden 1.
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 CPU Replacement: adım 7, 1 resimden 1.
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 CPU Replacement: adım 8, 1 resimden 1.
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 CPU Replacement: adım 9, 2 resimden 1. Toshiba Satellite L455D-S5976 CPU Replacement: adım 9, 2 resimden 2.
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 CPU Replacement: adım 10, 3 resimden 1. Toshiba Satellite L455D-S5976 CPU Replacement: adım 10, 3 resimden 2. Toshiba Satellite L455D-S5976 CPU Replacement: adım 10, 3 resimden 3.
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 CPU Replacement: adım 11, 1 resimden 1.
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 CPU Replacement: adım 12, 1 resimden 1.
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 CPU Replacement: adım 13, 1 resimden 1.
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 CPU Replacement: adım 14, 3 resimden 1. Toshiba Satellite L455D-S5976 CPU Replacement: adım 14, 3 resimden 2. Toshiba Satellite L455D-S5976 CPU Replacement: adım 14, 3 resimden 3.
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 CPU Replacement: adım 15, 1 resimden 1.
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 CPU Replacement: adım 16, 1 resimden 1.
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
  17. Toshiba Satellite L455D-S5976 CPU Replacement, CPU: adım 17, 1 resimden 1.
    • Remove the two Phillips #1 3mm screws from the fan using a Phillips #1 screwdriver.
  18. Toshiba Satellite L455D-S5976 CPU Replacement: adım 18, 1 resimden 1.
    • Remove the two cables from the fan.
  19. Toshiba Satellite L455D-S5976 CPU Replacement: adım 19, 2 resimden 1. Toshiba Satellite L455D-S5976 CPU Replacement: adım 19, 2 resimden 2.
    • LIft up on the fan and remove it from the computer.
  20. Toshiba Satellite L455D-S5976 CPU Replacement: adım 20, 1 resimden 1.
    • Remove the six 6mm screws from the motherboard with a #1 phillips screwdriver.
  21. Toshiba Satellite L455D-S5976 CPU Replacement: adım 21, 1 resimden 1.
    • Remove the lone 10mm screw from the motherboard with a phillips #1 screwdriver.
  22. Toshiba Satellite L455D-S5976 CPU Replacement: adım 22, 2 resimden 1. Toshiba Satellite L455D-S5976 CPU Replacement: adım 22, 2 resimden 2.
    • Remove the motherboard with your hands by carefully lifting up and pulling out.
  23. Toshiba Satellite L455D-S5976 CPU Replacement: adım 23, 2 resimden 1. Toshiba Satellite L455D-S5976 CPU Replacement: adım 23, 2 resimden 2.
    • Remove the four Phillips #1 6mm single coil pickup screws from the cooling unit and remove the cooling unit.
  24. Toshiba Satellite L455D-S5976 CPU Replacement: adım 24, 2 resimden 1. Toshiba Satellite L455D-S5976 CPU Replacement: adım 24, 2 resimden 2.
    • Using a flathead screwdriver, undo the lock on the CPU with a half turn in the counterclockwise direction.
    • Remove the CPU by lifting up on the chip.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
NateJohnson
1.047 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-26, Maness Winter 2014 Cal Poly, Team 9-26, Maness Winter 2014 üyesi
CPSU-MANESS-W14S9G26
4 Üyeler
1Rehber Yorum
Just be vary careful with unplugging any connectors. one false step and you could wind up with some more problems.
harh027213 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 11
Son 30 gün: 17
Her zaman: 3,914
