Ana içeriğe geç
Giriş
The RAM is an essential part of the computer that helps it run. Without the RAM, the computer will be slower and will not have as much memory. This guide will give the steps necessary to replace the RAM.
Parçalar
Hiçbir parça belirtilmedi.
  1. Unscrew the 4mm screw from the middle panel using a Phillips #1.
    • Unscrew the 4mm screw from the middle panel using a Phillips #1.
  2. Lift up on the middle panel and remove it.
    • Lift up on the middle panel and remove it.
  3. MacBook Pil Tamir Setleri
    Başlangıç $69.99
    Buy Now
    Başlangıç $69.99
    Buy Now
  4. Pull the right clip to the right and left clip to the left using your right and left hands respectively.
    • Pull the right clip to the right and left clip to the left using your right and left hands respectively.
  5. Once the clips have been removed, the RAM will pop up.
    • Once the clips have been removed, the RAM will pop up.
  6. Slide the RAM out of its position and remove it.
    • Slide the RAM out of its position and remove it.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
NateJohnson
985 İtibar
5 adet Kılavuz yazıldı
Takım
Cal Poly, Team 9-26, Maness Winter 2014 Cal Poly, Team 9-26, Maness Winter 2014 üyesi
CPSU-MANESS-W14S9G26
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 5
Son 30 Gün: 13
Her zaman: 1,189
