Ana içeriğe geç
Toshiba Satellite L455D-S5976 WIfi Card Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L455D-S5976 WIfi Card Replacement, Wifi Card: adım 1, 1 resimden 1.
    • Unscrew the Phillips #1 4mm screw from the middle panel using a Phillips #1 screwdriver.
  2. Toshiba Satellite L455D-S5976 WIfi Card Replacement: adım 2, 1 resimden 1.
    • Remove the middle panel by lifting up and out.
  3. Toshiba Satellite L455D-S5976 WIfi Card Replacement: adım 3, 1 resimden 1.
    • Remove the two Phillips #1 6mm screws from the wifi card using a Phillips #1 screwdriver.
    Add markers indicating where the screws are.
    Atlanta Nguyen - Yanıt
  4. Toshiba Satellite L455D-S5976 WIfi Card Replacement: adım 4, 1 resimden 1.
    • Unsnap the two cables from the wifi card.
    Add markers indicating where cables are.
  5. Toshiba Satellite L455D-S5976 WIfi Card Replacement: adım 5, 1 resimden 1.
    • Remove the wifi card using your hands.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
NateJohnson
1.047 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-26, Maness Winter 2014 Cal Poly, Team 9-26, Maness Winter 2014 üyesi
CPSU-MANESS-W14S9G26
4 Üyeler
Bir Yorum
Wonder if I did change the Wi-Fi card and it stil doesn't work
chrisww3297 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 1,093
