Giriş
Removing the keyboard from this laptop is a very simple and easy process. It should be noted that even though it is simple, it is equally as easy to push a component on the hard drive out of place since some parts of the motherboard are exposed under the keyboard
Neye ihtiyacın var
Open the laptop and locate the plastic strip just above the keyboard.
With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
Bir başkası bu kılavuzu tamamladı.
