Ana içeriğe geç
Toshiba Satellite L505 Laptop Keyboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: adım 1, 3 resimden 1. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: adım 1, 3 resimden 2. Toshiba Satellite L505 Laptop Keyboard Replacement, Keyboard: adım 1, 3 resimden 3.
    • Open the laptop and locate the plastic strip just above the keyboard.
    • With care, slide the prying tool into an end and lift it up until you hear an audible click, meaning it has separated.
    • Slowly slide a finger or the prying tool under and follow the strip to the opposite end, completely detaching the strip.
  2. Toshiba Satellite L505 Laptop Keyboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite L505 Laptop Keyboard Replacement: adım 2, 2 resimden 2.
    • Remove the four screws using the Phillips #1 screwdriver.
  3. Toshiba Satellite L505 Laptop Keyboard Replacement: adım 3, 2 resimden 1. Toshiba Satellite L505 Laptop Keyboard Replacement: adım 3, 2 resimden 2.
    • Gently push the clip back as you lift the top of the keyboard towards you.
    • There is a cable connecting the keyboard to the motherboard so do not lift the keyboard all the way out yet.
  4. Toshiba Satellite L505 Laptop Keyboard Replacement: adım 4, 3 resimden 1. Toshiba Satellite L505 Laptop Keyboard Replacement: adım 4, 3 resimden 2. Toshiba Satellite L505 Laptop Keyboard Replacement: adım 4, 3 resimden 3.
    • Gently disconnect the connector strip by pushing the white clips forward.
    • Carefully pull the strip out of its port.
    • Remove the keyboard from the device.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Matias
1.019 İtibar
9 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 17
Her zaman: 1,229
