Ana içeriğe geç
Toshiba Satellite L505D-GS6000 Battery Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L505D-GS6000 Battery Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite L505D-GS6000 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Battery Replacement: adım 2, 1 resimden 1.
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
Sonuç
Adam Dellicker
539 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Covino Spring 2018 UMass Dartmouth, Team S4-G2, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G2
2 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 10
Son 30 gün: 25
Her zaman: 400
