Ana içeriğe geç
Toshiba Satellite L505D-GS6000 Disk Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: adım 1, 2 resimden 1. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Battery: adım 1, 2 resimden 2.
    • Shut down the computer and disconnect all cables.
    • Flip the computer over so that the bottom is facing up.
    • Slide right switch above the battery so that it is in the rightwards position.
  2. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: adım 2, 1 resimden 1.
    • Push and hold the left-most switch in the leftward position.
    • While holding the left switch in position, lift up on the battery from the groove in the casing and remove.
  3. Toshiba Satellite L505D-GS6000 Disk Drive Replacement, Disk Drive: adım 3, 1 resimden 1.
    • Remove the M2 5x6 mm screw pointed out in the picture using the Phillips #0 screwdriver.
    • You do not need to remove anything else in order to take out the disk drive.
  4. Toshiba Satellite L505D-GS6000 Disk Drive Replacement: adım 4, 1 resimden 1.
    • Gently slide the disk drive out to the right until it is removed from the computer.
    • If the disk drive doesn’t easily slide out then there is possible damage on the inside of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Adam Dellicker
539 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S4-G2, Covino Spring 2018 UMass Dartmouth, Team S4-G2, Covino Spring 2018 üyesi
UMASSD-COVINO-S18S4G2
2 Üyeler
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 9
Her zaman: 401
