Ana içeriğe geç
Toshiba Satellite L55-A Back Cover Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L55-A Back Cover Replacement, Remove the RAM cover: adım 1, 1 resimden 1.
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A Back Cover Replacement: adım 2, 2 resimden 1. Toshiba Satellite L55-A Back Cover Replacement: adım 2, 2 resimden 2.
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A Back Cover Replacement, Disconnect the ethernet connector cable: adım 3, 3 resimden 1. Toshiba Satellite L55-A Back Cover Replacement, Disconnect the ethernet connector cable: adım 3, 3 resimden 2. Toshiba Satellite L55-A Back Cover Replacement, Disconnect the ethernet connector cable: adım 3, 3 resimden 3.
    • Use an opening tool to pry up the ethernet connector cable from its socket near the RAM module.
    • Disconnect the cable.
    • During reassembly, make sure you re-insert this connector right-side-up. The connector is keyed to plug in only one orientation, so if it doesn't slide into place easily, turn it around and try the other way.
  4. Toshiba Satellite L55-A Back Cover Replacement, Remove the back cover: adım 4, 1 resimden 1.
    • Remove the thirteen 6.8 mm long Phillips screws securing the back cover.
  5. Toshiba Satellite L55-A Back Cover Replacement: adım 5, 3 resimden 1. Toshiba Satellite L55-A Back Cover Replacement: adım 5, 3 resimden 2. Toshiba Satellite L55-A Back Cover Replacement: adım 5, 3 resimden 3.
    • Insert the point of an opening pick in the seam between the SuperMultiDrive and the rest of the back cover.
    • Push the SuperMultiDrive's lip away from the back cover to disconnect the drive.
    • Slide the drive out of the bay and remove it from the laptop.
  6. Toshiba Satellite L55-A Back Cover Replacement: adım 6, 2 resimden 1. Toshiba Satellite L55-A Back Cover Replacement: adım 6, 2 resimden 2.
    • The back cover is still held in place by plastic clips.
    • Insert the point of an opening pick into the back cover seam near the ethernet port.
    • Twist the pick to release the plastic clips along the edge.
  7. Toshiba Satellite L55-A Back Cover Replacement: adım 7, 3 resimden 1. Toshiba Satellite L55-A Back Cover Replacement: adım 7, 3 resimden 2. Toshiba Satellite L55-A Back Cover Replacement: adım 7, 3 resimden 3.
    • Grasp the loosened back case edge with your hand and lift it slowly away from the laptop. The remaining clips should release with ease.
    • If you meet significant resistance, stop and check for forgotten screws.
    • Remove the back cover.
    • To reinstall the back cover, align the cover and press along the edges to snap the clips back in place.
Sonuç
Arthur Shi
282.883 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
119 Üyeler
19.481 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 757
