Ana içeriğe geç
Toshiba Satellite L55-A RAM Module Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM cover: adım 1, 1 resimden 1.
    • Before you begin, be sure to power down your laptop.
    • Flip the laptop over so that the back cover is facing up.
    • Unscrew the captive Phillips screw securing the RAM cover.
  2. Toshiba Satellite L55-A RAM Module Replacement: adım 2, 2 resimden 1. Toshiba Satellite L55-A RAM Module Replacement: adım 2, 2 resimden 2.
    • Lift up the edge of the RAM cover and remove it.
  3. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: adım 3, 3 resimden 1. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: adım 3, 3 resimden 2. Toshiba Satellite L55-A RAM Module Replacement, Remove the RAM module: adım 3, 3 resimden 3.
    • This step shows how to remove a RAM module.
    • Use your fingers to spread the two metal clips securing the edge of the RAM module. This should free the module and cause it to pop up slightly.
    • Pull the RAM module out of its slot and remove it.
  4. Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: adım 4, 3 resimden 1. Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: adım 4, 3 resimden 2. Toshiba Satellite L55-A RAM Module Replacement, Replace the RAM module: adım 4, 3 resimden 3.
    • This step shows how to insert a RAM module.
    • Insert the replacement RAM at a shallow angle into the RAM slot until the gold contacts are fully socketed.
    • Use your fingers to gently press the RAM module's edges down until both metal clips snap into place.
    • If your laptop will not properly recognize the installed RAM, unseat and reseat the RAM, making sure that all modules are fully locked in place.
Sonuç
Arthur Shi
283.063 İtibar
587 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.535 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 242
