Ana içeriğe geç
Toshiba Satellite L55W-C5256 RAM Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L55W-C5256 RAM Replacement, Battery: adım 1, 1 resimden 1.
    • Before beginning this repair, power off your device and unplug all cables and accessory devices.
    • Flip the laptop over so that the model numbers are facing the ceiling.
  2. Toshiba Satellite L55W-C5256 RAM Replacement: adım 2, 1 resimden 1.
    • Use a Phillips #00 screwdriver to remove the 10 screws that secure the back cover to the device.
  3. Toshiba Satellite L55W-C5256 RAM Replacement: adım 3, 1 resimden 1.
    • Gently use an iFixit opening tool to separate the back cover from the laptop. Go around all edges until plastic clips are completely free.
    • Ensure all plastic clips have been freed. Attempting to forcefully remove the back cover could result in damage to your device.
  4. Toshiba Satellite L55W-C5256 RAM Replacement: adım 4, 1 resimden 1.
    • Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Disconnect the battery connector cable from the motherboard.
  5. Toshiba Satellite L55W-C5256 RAM Replacement: adım 5, 1 resimden 1.
    • Using a Phillip's #00 screwdriver, remove the four 7.0 mm screws that secure the battery to the motherboard.
  6. Toshiba Satellite L55W-C5256 RAM Replacement: adım 6, 1 resimden 1.
    • Lift the battery from the motherboard.
  7. Toshiba Satellite L55W-C5256 RAM Replacement, RAM: adım 7, 3 resimden 1. Toshiba Satellite L55W-C5256 RAM Replacement, RAM: adım 7, 3 resimden 2. Toshiba Satellite L55W-C5256 RAM Replacement, RAM: adım 7, 3 resimden 3.
    • Reminder: Before touching any component inside your device, ensure you are properly grounded with an anti-static band.
    • Using your forefinger, gently pull on the left bracket that secures the RAM to the motherboard.
    • Using your forefinger, gently pull on the right bracket that secures the RAM to the motherboard.
    • When successfully freed from the locking brackets, the RAM stick will "pop up" at a 45-degree angle.
    • Lift the RAM stick from the motherboard.
  8. Toshiba Satellite L55W-C5256 RAM Replacement: adım 8, 1 resimden 1.
    • Repeat step 7 to remove the second RAM stick.
    • When replacing the RAM sticks, re-insert them at the same 45-degree angle at which they were removed.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jennifer
777 İtibar
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 369
