Ana içeriğe geç
Toshiba Satellite L55t-B5271 Back Panel Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L55t-B5271 Back Panel Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L55t-B5271 Back Panel Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L55t-B5271 Back Panel Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Back Panel Replacement: adım 2, 2 resimden 1. Toshiba Satellite L55t-B5271 Back Panel Replacement: adım 2, 2 resimden 2.
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Back Panel Replacement: adım 3, 3 resimden 1. Toshiba Satellite L55t-B5271 Back Panel Replacement: adım 3, 3 resimden 2. Toshiba Satellite L55t-B5271 Back Panel Replacement: adım 3, 3 resimden 3.
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Back Panel Replacement, Back Panel: adım 4, 3 resimden 1. Toshiba Satellite L55t-B5271 Back Panel Replacement, Back Panel: adım 4, 3 resimden 2. Toshiba Satellite L55t-B5271 Back Panel Replacement, Back Panel: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
Sonuç
Garrett Garofalo
298 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G3, Peak Spring 2018 UMass Dartmouth, Team S3-G3, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G3
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 493
