Ana içeriğe geç
Toshiba Satellite L55t-B5271 Motherboard Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L55t-B5271 Motherboard Replacement, Battery: adım 1, 3 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement, Battery: adım 1, 3 resimden 2. Toshiba Satellite L55t-B5271 Motherboard Replacement, Battery: adım 1, 3 resimden 3.
    • Make sure you turn the laptop off first.
    • Close the laptop lid and flip it over so that Toshiba logo is facing down.
  2. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 2, 2 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 2, 2 resimden 2.
    • Remove the two 6.5 mm Phillips head screws indicated using a Phillips #00 screw driver.
  3. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 3, 3 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 3, 3 resimden 2. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 3, 3 resimden 3.
    • Once the screws are removed, slide the battery pack out of the computer.
  4. Toshiba Satellite L55t-B5271 Motherboard Replacement, Back Panel: adım 4, 3 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement, Back Panel: adım 4, 3 resimden 2. Toshiba Satellite L55t-B5271 Motherboard Replacement, Back Panel: adım 4, 3 resimden 3.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    • Remove all 6.5 mm Philips head screws on the back cover of the laptop with a Philips #00 screwdriver.
    • Use the plastic opening tool to remove the back cover from the laptop.
    • Be aware that static discharge can cause damage to sensitive electrical components within the computer. To avoid this you can wear an anti-static wrist strap.
  5. Toshiba Satellite L55t-B5271 Motherboard Replacement, RAM: adım 5, 3 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement, RAM: adım 5, 3 resimden 2. Toshiba Satellite L55t-B5271 Motherboard Replacement, RAM: adım 5, 3 resimden 3.
    • This laptop does not have a RAM present. Follow instructions to replace your own.
    • Evenly press down on the clips on either side of the RAM stick.
    • To pull out the RAM stick, be sure to align the notches on the RAM stick with the notches in the RAM holder.
  6. Toshiba Satellite L55t-B5271 Motherboard Replacement, Wireless Card: adım 6, 2 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement, Wireless Card: adım 6, 2 resimden 2.
    • Remove the ribbon by flipping up the tabs and using the black tweezers to gently pull the ribbon out from both ends.
  7. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 7, 3 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 7, 3 resimden 2. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 7, 3 resimden 3.
    • Remove the tape from the card.
    • Disconnect the wires using the #4 black spudger tool.
  8. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 8, 1 resimden 1.
    • Remove the 3mm Phillips head screw with a Phillips #00 screwdriver.
  9. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 9, 2 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 9, 2 resimden 2.
    • Pull up on the wireless card and remove it from the device.
  10. Toshiba Satellite L55t-B5271 Motherboard Replacement, CD Drive: adım 10, 2 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement, CD Drive: adım 10, 2 resimden 2.
    • Remove the 3 mm Philips head screw that connects the CD drive to motherboard with a Phillips #00 screwdriver.
  11. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 11, 2 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 11, 2 resimden 2.
    • Gently pull the CD drive out, disconnecting it from the motherboard connector marked in blue.
  12. Toshiba Satellite L55t-B5271 Motherboard Replacement, Cooling Fan with Heat Sink: adım 12, 3 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement, Cooling Fan with Heat Sink: adım 12, 3 resimden 2. Toshiba Satellite L55t-B5271 Motherboard Replacement, Cooling Fan with Heat Sink: adım 12, 3 resimden 3.
    • The ribbon and wire must be moved out of the way of the fan.
    • Using a black tweezer tool, lift the tab holding the ribbon in place and then gently pull it out.
    • Using the same tweezer tool, again lift the tab holding the wires in place and gently pull them out.
  13. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 13, 2 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 13, 2 resimden 2.
    • Unscrew the two 3mm Phillips head screws on each fan using the Phillips #00 screwdriver.
  14. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 14, 3 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 14, 3 resimden 2. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 14, 3 resimden 3.
    • Unscrew the four, 3mm Phillips head screws holding the last piece to the laptop using a Phillips #00 screwdriver.
    • Gently pull the cooling fan with heat sink off the laptop and set aside.
  15. Toshiba Satellite L55t-B5271 Motherboard Replacement, Motherboard: adım 15, 3 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement, Motherboard: adım 15, 3 resimden 2. Toshiba Satellite L55t-B5271 Motherboard Replacement, Motherboard: adım 15, 3 resimden 3.
    • Disconnect all of the ribbons by lifting the tabs and gently pulling them out.
  16. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 16, 3 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 16, 3 resimden 2. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 16, 3 resimden 3.
    • Remove the wires from the motherboard using the tweezers.
  17. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 17, 1 resimden 1.
    • Remove all seven of the 3mm Phillips head screws with the Phillips #00 screwdriver.
  18. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 18, 3 resimden 1. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 18, 3 resimden 2. Toshiba Satellite L55t-B5271 Motherboard Replacement: adım 18, 3 resimden 3.
    • Gently lift the motherboard from the back of the laptop.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Noelle Dulude
480 İtibar
4 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G3, Peak Spring 2018 UMass Dartmouth, Team S3-G3, Peak Spring 2018 üyesi
UMASSD-PEAK-S18S3G3
3 Üyeler
8 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 21
Her zaman: 921
