Ana içeriğe geç
Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: adım 1, 2 resimden 1. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement, CD/DVD Drive: adım 1, 2 resimden 2.
    • Unscrew the three 4.6 mm screws holding the panel using a #1 size Phillips head screwdriver. The panel is centered on the bottom of the laptop.
  2. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: adım 2, 1 resimden 1.
    • Remove the panel, firmly lifting from the indent. It is recommended that you leave the screws in the panel.
  3. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: adım 3, 1 resimden 1.
    • Unscrew the 3.9 mm screw located at the bottom right of the panel.
  4. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: adım 4, 1 resimden 1.
    • Use a plastic opening tool to pry the CD drive out of the casing.
  5. Toshiba Satellite L655D-S5095 CD/DVD Drive Replacement: adım 5, 1 resimden 1.
    • Once the CD drive is out far enough to grip, pull the CD drive out to the right.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Torey
210 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G7
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 24
Her zaman: 2,330
