Ana içeriğe geç
Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement
Neye ihtiyacın var
  1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: adım 1, 3 resimden 1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: adım 1, 3 resimden 2. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement, Chat Camera and Microphone Daughter Board: adım 1, 3 resimden 3.
    • Using a plastic opening tool, remove the four plastic stickers located on the four corners of the LCD screen assembly. These plastic stickers are covering screws.
    • Use a Phillips #1 screwdriver to remove the now uncovered 5.75mm screws and place them to the side.
  2. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: adım 2, 2 resimden 1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: adım 2, 2 resimden 2.
    • With a plastic soft pry tool, open up the laptop display assembly by methodically prying from left to right. Be careful to not damage any internal circuitry.
    • Do not attempt to pry apart the bottom, the LCD assembly never gets fully disassembled in this tutorial.
  3. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: adım 3, 2 resimden 1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: adım 3, 2 resimden 2.
    • Remove the 2 pieces of black tape using a sharp tool to free the camera board, note that the camera board is still connected to a cable.
  4. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: adım 4, 2 resimden 1. Toshiba Satellite L655D-S5095 Chat Camera and Microphone Daughter Board Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Carefully disconnect the camera board from the laptop. We used tweezers.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Robby
52 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 7-7, Maness Winter 2013 Cal Poly, Team 7-7, Maness Winter 2013 üyesi
CPSU-MANESS-W13S7G7
5 Üyeler
6 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 25
Her zaman: 2,672
